will an f22a4 fit a 1997 odyssey
This topic is closed.
    like the title says will an f22a4 fit a 1997 odyssey with a f22b6. if not what do i have to change so it can fit?
    R.I.P 93 CB7 COUPE
    Team modA in the proess
    anyone???
    R.I.P 93 CB7 COUPE
      Originally posted by str8jdmswap View Post
      anyone???
      if it came with an f-motor, then another f-motor should be a direct fit. Same design, different head. mounts should be the same.
        but what im wondering is. do any of the plugs change because i think that is an obd2. and my f22a4 is an obd1
        R.I.P 93 CB7 COUPE
          Hmm I think you would have some major problems attempting that swap. OBD2>1 is fairly easy, but 1>2 has got to be pretty hard. You would have to use an obd 2>1 conversion harness, I'm not sure on what else would need to be done though.
            anyone???
            You waited half an hour in the middle of the night.
            Fail.
            The swap would be 100% illegal. You are not allowed by law to put an older engine into a newer car (especially when it's OBD1 into an OBD2 car).
            Thread locked.
