what can i put in my car to get better gas mileage?
how to acheive better gas mileage
a manual transmission.
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
Originally posted by ASTCB7 View Postwhat can i put in my car to get better gas mileage?
or a tune.
Originally posted by PointBlank View PostNew air filter and spark plugs.
Oil change wouldn't hurt.
Fuel injector cleaner.Originally posted by cb7addict View Posthaving the right amount of air in your tires helps too.
1. complete ignition tune up. Plugs, wires, cap, rotor.
2. Fuel filter, and clean non restrictive air filter
3. the correct oil and a new filter
If you have any vacuum leaks, these are fuel eaters! Fix them! such as, broken vacuum lines, intake manifold gasket, a worn/old or bad map sensor!
Definitely keep your coolant temps sensors in prime condition! IF they dont see operating temp they wont go into adaptive or closed loop.
Low coolant needs to be topped off!
Keep your valves adjusted right! Make sure your timing belt is in time! a stretching old belt will also start to eat at gas mileage.
Good tires, tire pressure, and good tire alignment is very crucial to mpg.
These are just the quick ones i can think of...
Definitely need to add...
good switching o2 sensors,
non restricting exhaust, a failed cat or partially plugged catalytic converter will cause the engine to work harder to expel the exhaust.
Weak coils will also lower mpg. if you see any carbon tracking inside the dizzy when you change the cap and rotor. you might want to look into a new coil.
also, use the recommend fuel grade. Some people believe that if 87 works good, then 92 will really wake it up. Not so. higher octane ratings slow the burn time down to prevent predetonation. if your car recommends using 87 use, that's the fuel grade the honda engineers found to get the best performance and mpg. Older cars will sometimes be picky and need to have a higher octane gas due to the raised, though minimally, compression due to carbon build up on the pistons. you'll have to play around with a tank or two to see if switching gas grades will fix a slight miss, or make it worse.Last edited by cb7_reverand; 12-18-2009, 06:40 PM.
02 sensor is one if the most commin things that kills gas milage, get that replace and yall shall see gas improvements
Your own driving habits play a HUGE part in it as well. A heavy foot can cost you 5mpg or more. Drive between 2k and 3k RPM. I always shift at 3 when I'm being conservative.
Also, if you have a lot of heavy shit in your car... get rid of it. I'm a musician, and I would often carry my equipment around in my back seat. 150-200lbs, usually. That extra weight made a noticeable difference in my gas mileage.
Follow a Hummer H2, those things are like bricks...let them take up all the aero drag lol
or option 2:
-get a lip (helps divert air away from chassis underside)
-skinnier tires (less aero drag)
-lower you car (less aero drag)
-use synthetic oil (less friction in engine and more power too)
-dont use A/C when you can
-close all windows when going over 45-50mphLast edited by Losiracer2; 12-18-2009, 10:16 PM.
Originally posted by deevergote View PostOr just draft a semi...
I tried it in the Fit. I couldn't get it to pull me along enough. Either the Fit is too aerodynamic, or I wasn't close enough.Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.TypeG x2
Deevergote
BillKisme
