chime mod
    chime mod
    hey guys.
    thanks to my new radio im now sitting in my car with the labtop using the aux option to listen to music and type this and asking what the chime speaker looks like so i may remove to replace it with a strobe.
    yea i want to change the chimey beeepbeeepbeeep crap to a flashing advisery. Ill post the results after i find the bugger.
    any thoughts?
    Originally posted by Paradien View Post
    hey guys.
    any thoughts?
    I dont understand. Could you give me specific information?
      just the door chimer, it makes a repetative 3 beeps.
        Okay when you open the door it makes that 3 beeps but you want to make it flash on your keyhole with strobe lights?
        Only way is unplugged it. I'll be back with information.
          not on the keyhole. But yeah i wish to remove it , and modify a strobe bulb or led in its place. Personally the beeping doesnt do any thing, it tells you if a door is open on the dash. Thats all i need to tell me a door is open and not a annoying beep. A nice blinking light like the one they used on my viper alarm is better.
            i think that the unit is down near the fuse box. im not sure on how you would swap it with a bulb i think its a relay type thing.
            life is as good as you make it. So forget what people say and do what makes you happy
              I found it. I looked in the wireing diagram in the haynes manual. Only problem now is that its located behind the whole fuse block. the chime is fairly simple, if i cant modify a led/strobe ill just remove it, no point in it for me.
                Let us know how it goes!
                I've also thought about modifying this before. Not getting rid of it, but changing the speaker or board to that of a later Honda. With a chime that is less irritating.
                My pictures/photos will return soon...
                  VW mexican hat dance!
                  life is good.
                    Hey guys
                    I made some progress i like to share.
                    I found the chimer.
                    The chimer is on the board of the control unit ("trw 38600-sm5-a02") located on the interior fuse block.
                    As you can see it is easy to access which makes things a lil bit easier to experiment with. I can even take the board completely out of the plastic case.
                    In this pic the large drum like object in the center is the speaker for the chimer, i see these on motherboards for pc's all the time, i usual remove them so i dont hear the boot chime, but in this case the chime is soldered in place, but no worrys here.
                    Im gonna go to the local junk yard and pull another one of these out to experiment with, i will take a soldering gun to it to remove it and in its place wire up a led that i can run some were on my dash.
                    On another note , the chime is on the control unit, meaning it does more than annoy you when a door is open, when i removed it i found that everything worked except the windows. This board controls all the window relays.
                    Hopefully this will work. Ill keep everyone posted on the results.
                      i love this idea.
                      Too bad i don't own a cb anymore or id be doing this tomorrow LOL!
                        Originally posted by Ralphie View Post
                        i love this idea.
                        X2,
                        I might have to try this. thanks
                        Click picture for MRT
                        Sparkin CB7
                          Best of luck, i might do that too i hate that bell lol
                            Hey guys
                            I found the chimer.
                            Thats the ICU which I THINK also controls the way the corners flash. I think the windshield wipers are hooked to it too.
                            I can't think of a way to change the tone, but hooking an LED might work. I doubt it will be very bright though as LEDs operate on current and I assume that board doesn't put much current through the speaker. A solution though would be to possibly use a relay, having the output from that beeper as the activator than putting the light on the switched circuit.
                            For me, I don't mind the chime and beep... Its a good reminder for me to remove the damn keys!
                            Now the only thing I don't like is the chiming of the headlight reminder. It doesn't seem that that sound comes from that box though as the sound is more like small bells being hit. (Sometimes mine fucks up and has like a half bell for a little while... lol)
                            It would be possible I think to hook a different sound up to that though as it sends the chimer a signal to turn on, and you could just hook some pre-recorded sound on a chip with a speaker hooked to it.
                              I googled the serial i posted.
                              http://www.hondapartsnow.com/genuine...0-SM5-A02.html
                              Like i said this is a experiement, parking lights blinkers highbeams , all function without it.
