f22?
    f22?
    k ppl i now that mine is a f22a4 and ive read some threads where u guys mention other ones but im a noob so wts the difference between this 1 and the other1s
    Search before you post noob and you will get great results!!
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
      Was the name calling even fucking neccessary?
      OP , google and type Honda F Series.
      Feeding trolls is my profession and hobby.
      I have the ability to speak and write the idiot language.
      Masters Degree on Trolling & Counter-Trolling
        I learned recently that you should search, then post questions based solely on what you still don't understand. It will keep people from shooting you the "noob" label so frequently and/or flaming and bashing you.
        So do a search and read around. You'll find what you want to know. After all, we can't do all the work for you.
        R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
          May not be 100% accurate, it is from Wikipedia after all, but it's pretty straight forward.
          F22A
          This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
          Specifications
          * Bore × Stroke: 85.0 × 95.0 mm
          * Displacement: 2156 cc
          * Valve Configuration: SOHC, 16 valves, non-VTEC
          * Compression ratio: 8.8:1
          * Max power:
          o F22A1: 125 hp (93.21 4 kW) @ 5200 rpm. NOTE* The 1992-1996 Prelude S had a F22A1 but because of a different more aggressively tuned ECU (P12), the power output was 135 hp (101 kW).
          o F22A4: 130 hp (96.94 kW) @ 5200 rpm. The F22A4 is the same motor as the F22A1 but it has slightly more power due to a tubular designed header and slightly bigger exhaust piping.
          o F22A6: 140 hp (104.40 kW) @ 5600 rpm. The F22A6 is the same as the F22A1 except for a slightly more aggressive camshaft, a better flowing cast exhaust manifold, a different more aggressively tuned ECU (PT6), and a different intake manifold that utilizes IAB's and also has a bigger plenum. The F22A6 also has a windage tray in the oil pan, and stiffer valve springs to accommodate the more aggressive camshaft.
          o F22A7: 140 hp (104.40 kW) @ 5900 rpm (147 hp/108 kW with manual transmission)
          * Max torque:
          o F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
          o F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
          o F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
          o F22A7: 145 ft·lbf (198 N m) @ 5000 rpm
            This guy gave great advice! Google is your friend.
            You'll find a really nice write up on all the honda f series engines on wikipedia.
              Lol, I was waiting for you to chime in Josh. I knew you'd do the work for him.
                evry 1s a noob at the beggining but yeah i did do my reaserch right after i posted it up lol
                  Download this:
                  http://www.mozilla.com/en-US/firefox/personal.html
                  It has a built in spell checker.
                    says a6 has a windage try in the oil pan, what is that.
                      None of you actually helped the OP in anyway at all, time for a break for you lot.
                      OP - the main differences are:
                      F22A4 has different exhaust manifold.
                      F22A6 has different exhaust manifold, ecu, and camshaft. The windage tray in the A6 is in the oil pan to try prevent the oil from splashing around so much
                      My 5.7 LS1 Holden Ute
                        Download this:
                        lol its the interned who cares how u spell things besides the google chrome kept changing my spelling words i'm edumacaded lol
                          Well in the future, when you go into detail about a possible problem, no one will be able to understand what your problem is. The more clearly you type, the better the chance of someone helping you.
                          Not trying to be a dick. I've just seen how the forum is, and I'm just trying to help you out.
                            more specifically, it prevents the crank from making too much turbulence and affecting the oil.
                              we should really say the a4 has a tubular design for the exhaust manifold while the a6 has a cast style exhaust manifold.
