shift cables or cable mount on the motor?
What's wrong with my clutch/tranny
Originally posted by cb7f20b View Postshift cables or cable mount on the motor?2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
I got a chance to take a closer look at things today. The master clutch cylinder fluid level is good, but there is a small amount of leakage under the dash. I had someone step on the clutch while I took a peek in the engine bay. There are no signs of leakage in the hydraulic system but I noticed that the slave is not actuating. Is it possible that either the master or slave could be the root of the problem?
I like going through the entire system as a whole. System = The process of movement. Example. You heard a snap so working from the wheels backwards doing the easiest stuff first you can inspect your wheels and axles to see if anything broke. Next check the transmission. If you can push the car while the shifter is in some gear, will the car roll? If not then the transmission is in a gear, you will want to check the shifter cables by having someone sit inside the cab and move the shifter while you watch the linkages on your transmission, if the shifter linkage move and the transmission shifter forks move then you want to try and move the shifter into a neutral position which will allow the car to roll freely. IF the shifter won't budge remove the linkages from the transmission and see if the shifter will move. If it does then you will need to remove the transmission and fix it or take it to a shop to be serviced. Moving on to other things you can check is the clutch line and clutch fork. With someone in the car stepping on the clutch pedal watch the slave cylinder for movement against the clutch fork. The fork should move a noticeable amount and not leak. Ask your assistant to hold the clutch pedal down and look for any pressure drop, the clutch fork will start to move back to the original position. If the fork moves freely with no leaks on either end of the system (clutch pedal to clutch fork) then it has nothing to do with your issue.Been a long time. Still alive...
Originally posted by theSOB View Postx2
Originally posted by des0ne View PostI got a chance to take a closer look at things today. The master clutch cylinder fluid level is good, but there is a small amount of leakage under the dash. I had someone step on the clutch while I took a peek in the engine bay. There are no signs of leakage in the hydraulic system but I noticed that the slave is not actuating. Is it possible that either the master or slave could be the root of the problem?
Have you done anything recently that may have damaged a line? That's the only other possible explanation, other than a bad cylinder.
It sounds like an axle for the following reasons.
1) It broke in first gear while leaving the parking lot. Which means you were prob turning and accelerating which puts alot of stress on the axles.
2)The speedo increases when the car is in gear. If the clutch were smoked it wouldnt turn the transmission.
3)The slave and master works to disengauge the engine from driving the trans. If either of them failed and the car was in any gear, the problem would be that the car wouldnt want to stop because the clutch wouldnt be able to disengauge the engine. Also the car would lurch forward if the car was started in gear with a bad master/slave.
4)Also ^ the pedal would be low or fall to the floor if there were a leak.
