car idles at 3000 RPM wtf?
    okay so i have a stupid problem and am out of ideas. i live in seattle and it been really cold latly and my ca decided to just start reving like the IACV went bad so i swapped it out had no affect so tried another one. i know they are both good. heard the cars run fine with them, but still not for me. so i start messing with the fast idle valve and tightin my intake. o yeah i have a f22a6 with h23 bottom and h22 top intake. so after doin all this my car just idles a 2500 then jumps up to 3400 when it gets hot. i am out of ideas. so please though out any ideas you might have to help me. im very annoyed .thank you
    Red Wagon DD - 1993 EX
    http://www.cb7tuner.com/vbb/showthread.php?t=172734
    Gray Wagon Project - 1992 LX
    http://www.cb7tuner.com/vbb/showthread.php?t=166337
    Try setting your idle.
    Turn car off.
    Unplug IACV and jump service connector in lower right passenger kick panel with a paper clip.
    Start car.
    Look on the throttle body for the adj. screw. It is in the top left corner on the side that the intake tube connects to.
    Turn screw until idle is around 500-700 RPM (the mark above 0 on the tach is 500).
    Turn car off.
    Un-jump service connector and plug IACV back in.
    Start, and enjoy!
      check all your vacuum lines to your intake, I had a buddy that had one plug off and it raised his rpm's at idle.
        thanks ill try to set the idle tomorrow, ive checked all my vacuums like three times all all capped or plugged like it was when i first had it running fine.
          To me, it sound like you have a bad Fast idle thermo valve.
          Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
          Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
            sounds like a bad fast idle thermostat valve just my .02
            Originally posted by Juice21
            thnx pimpette, your car inspired me to go lower
            Originally posted by GameChewer
            Shiit i heard that, you heard the queen!
              Driven the car yet? I had this problem when, after I lifted up my carpet to dynamat the floorboard, I didn't lay the carpet back down right and it caught my gas pedal, which pulled it down a little bit, and revved it up. if your car tries to take off as soon as you shift it in gear, your problem is something is opening the throttle.
                i doubled checked my carpet, tried setting the idle and nothing. im wondering if maybe my tps sensor is bad?
                  Does it still idle up and down? Or is it just staying steady really high?
                  If it's reving up and down I agree that the FITV bad, but if it's just idling really high, reset the idle.
                  Member's Ride Thread
                  Originally posted by mercyboy
                  I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                    So when you were setting your idle, you got it down to 600-700 RPM Right?
                    If you did, then the problem may lay in the IACV, Try taking it off and cleaning it with carb cleaner.
                    If you couldn't get it that low by using the screw on the tb, I think you may have other problems.
                    Try this.
                    Take your Intake tube off and look inside the tb.
                    Take a look at the plate on the inside of the tb. It should be closed nearly all the way with very little or no gap between the plate and tb.
                    Also, There are 2 holes on the inside of the tb right in front of that plate. They bypass air to the idle control valves. Try covering each of them with your finger while the engine is running and see if anything changes.
                    If nothing changes, It may be your TPS...
                      I would agree with that. When I did my coolant line re-routing, the idle would change due to the weather, in the winter to idle would jump to around 3000rpm's and in the summer, spring, fall it would be right around 750-800rpm's. Check your fast idle thermo valve.
                        i dont think its the tps i think it a vacumm leak or sumthing to do with the iacv or fitv cause frm my experment tps will not raise the rpms of your motor it will add more fuel but if the motor doesnt have more air coming in it will just runn richer i thought mine was going bad so i hooked my an ol tb i had laying around to mi wiring harness and it did nothing even when i turned the tb
                        h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
                          well i got a new fast ldke valve and plan to put that on today to see if that is the problem because now its back to revving up and down. my dumbass had a friend check the TB and he took it off and forgot to plug back in the TBS that's why it was rving to 300 made me feeling really dumb but any way today ima try that new fast idle valve. hope it works.
