speedo meter
    speedo meter
    so recently my speedometer stopped working for good. it was wierd because every once in a while it would stop then i would hit a bump or somthin and it would pop back up so i dont know what it could be any ideas?
    replace your speed sensor
      yes, check your speed sensor.
      http://techauto.awardspace.com/vss.html
        how much does the part run???
          Should be under $30 from parts store.
            Snatch one from the junk yard I was in luck when I had this problem. I went to U Pull It and was able to snach 3 of them. 1 looked brand new! They were like $6 a piece.
              does it matter from auto to manual?
                also check your ground under the lower rad hose at the thermostat [a main grounding point] and pull the ecu fuse and put it back in
