I just did a oil change on the accord, and utilized 10w40 per a buddy of mine who stated itd be better for the engine, i actually feel a better response from the motor, could this be due to the thicker oil?
10w40 safe?
At least according to what some people told me, putting thicker oil on an older engines is recommended. Since it is less likely to leak if the gaskets or seals are deteriorated.
But that's about it.Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
placebo effect1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Originally posted by honda_kid View Posti dont remember which gran turismo it was, but if you changed the oil, it gave you another ~5-10hp.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
What is a Multi-Viscosity Oil
So which oil is better? Heavy or light weight oil? Fortunately, multi-viscosity oils serve the purpose of having the best characteristics of both. A designation of 10W30, means that the oil has a lower viscosity rating (good in colder temperatures) and resists temperature breakdown like a 30 weight. By the way, the W designation on the label stands for "winter use," not weight.
Multi-viscosity oils may seem like the perfect solution, but there is a trade-off. All oils will break down when exposed to heat. Whether a synthetic motor oil or regular motor oil, the additives (called polymers) used to create multi-viscosity oils have been shown to leave harmful deposits when they break down.
Perfectly fine, justs resist temperature alittle better
BTW has anybody ever tried 0w20???Last edited by rayray91; 12-14-2009, 03:04 AM.
