VERY BAD oil leak help
    There is oil dripping at a very fast rate from the back of my Cb's engine down onto the engine pipe.I left the car running in my driveway for about 45 mins and lost at least a 1/4 of a quart of oil.I have yet to look at it but I'm assuming it's the oil pressure switch.My rear main seal leaks but never this bad.Any advice?
    I know....I'm gunna lower it
    Which engine do you have? If you have the a6 then it could be the oil cooler o ring.
      a1
        by engine pipe, do you mean water pipe.
        black pipe that goes from water pump to thermostat?
        just curious if this is where your oil is.
        there is a plug for your balance shaft in the rear. make sure all wholes are bolted up.
        MadLab Racing
        Southern Maryland
          could be oil filter, oil sender, head gasket or rear main ..also check spark plugs to
            no the exaust pipe
              Hey do you change your own oil? Did you have a gasket stick on the oil filter housing then put another filter on top? Is the filter loose? Just stuff to check.
              My CB7 http://www.cb7tuner.com/vbb/showthre...hlight=phalpin
                x2
                diagnose the whole area.
                • put the car up on jacks
                • clean it up
                • put a piece of cardboard underneath
                • check where the oil is coming from
                problem solved
                Originally posted by visualpoet
                some owners think it's the best thing since titties
                  definitly wash the area, there is no reason for speculation it would be hard to guess. Just get that baby up on those jackstands, wash it, and run it again. If it's bad it should be easy to tell, if you are really having a hard time seeing the oil run down, get one of those oil leak detectors, they are like a buck each.. it's a dye that turns a certain color/illuminates with light if it touches oil*. area has to be cleaned thoroughly though.
                    From my reading and experience this can only be 2 things.
                    1) Oil cooler ring (easy job $15 - $20 and 1 hour max once you got the tools out and car up)
                    2) Oil Sender ($15 to $40 depending on used or new and again 1 hour)
                    Likely to be the oil cooler since it sounds like a strong leak.
                    If its not the oil cooler i suggest you change it anyway since its old now and known to give way also. Cheap anyway.
                    Rides:
                    Accord
                    92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
                    96-AUDM-2.2 VTiS- Heather Mist
                    CR-X
                    88-JDM-Si- Black
                    CR-X Del Sol
                    92-JDM-SiR "Transtop" Motegi Edition - Silver
                    95-JDM-SiR "Transtop" Daytona Edition - Silver
                    92-JDM-SiR "Transtop" - Black
                    Prelude
                    91-JDM-Si-4ws "Si States" - Phoenix Red
                    91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
                    91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
                    91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                      A1 doesn't have an oil cooler unless he put one in from another engine.
                      an oil cooler o-ring is only 3 bucks from Honda even then that's over priced for a small ring of rubber.
                      I think the OP should use Juan4DCB7's suggestion and get under there to find the culprit.
                      maybe it's the oil pan gasket because i did mine not too long ago but only applied sealant around the corners, when i started my engine, it would shoot oil out near the "stiffener bracket" for the transmission.
