having a major problem
    ever since i got my car, its always had some sort of cutting off problem and not starting back up for a minute. I've taken it to the honda dealerships and everything. all they did was replace the main relay, and all the ignition components. Now its gotten to where itll cut off in traffic and not crank back up until you cut it off and wait for about 60 seconds then it starts fine. WTF?
    COUPE K24
    Check your battery connections. I had loose and corrosion-covered connections, and the same thing happened to me.
      I had a customers car act very similar to that. It ended up needing an ignition switch. When you say they replaced all the ignition components, I'm assuming you mean plugs, wires, cap rotor . . . right?
      The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
        I keep forgetting about the ignition switch. That hasn't been a common problem, though it seems to be happening more and more lately.
          ill check the battery terminals.
          yes all the those parts replaced. coil too.
          it seems that my ignition switch was replaced because when i got the car, it had one that was removed and i have 2 keys to my car.
          COUPE K24
            how about your main relay???? i had that problem when i turned off my car and like 3 or 4 min later tried to start it back up and it wouldnt
              The main relay is always a possibility.
              As for the ignition switch... just because it was changed doesn't mean the one in there is good. The one in there could've come from a junkyard car that was also about to fail.
                Main relay was replaced already, he said so in the first post.
                It sounds like you've gone through all of the ignition stuff, move on to fuel. Try replacing the fuel filter, maybe it's clogged or something.
                1992 Prelude S w/swapped H22A
                  [QUOTE=benji;2342785]Main relay was replaced already, he said so in the first post.
                  this is very true looks like i need to read before throwing out ideas.
                    The Starter and the Main Relay did this to me...wasn't fun...anything out of the unusual?....beside the random shut off?
                    *Needs*
                    -New shocks
                    -Struts
                    -Drop
                    -Cleaning
                    -New Tires/Wheels
                    -New Window Tint
                    -Alot more lovin'
                      As far as "ignition components" go, what did Honda replace? Plugs, wires, cap and rotor? Did they replace the coil or ignitor? These are common things to go out, mostly the ignitor, based on your description.
                        It's also not unheard of for a new part to be defective.
                        That is very true. Read, then reply.
                        I made the same mistake... read through the first post when I first replied, but only read your post when I made the main relay suggestion myself.
                          what were the symptoms when the car was dying, did it come to an idle rpm, or were you on it? Was the car sputtering? Did it completely turn off? electircals were they still on? what happened when you went to turn to start it, did it crank over? more details please.
