I've been having this problem where my key wont come out of the ignition. The park light don't come on either. But the car is in park because I rocked it back and forth and it is in park but the light doesn't come on. But if I let it sit for a while it will come on and I can take my keys out with no problem. any idea's what it could be...
Key wont come out?
push hard on the shifter forward.
if not then now you have keyless entryWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Don't you love cold weather?
This often happens in the cold with my 90 DX. As others have said, pressing the shift selector all the way forward will often do the trick. In addition, I've noticed that it also tends to happen to my car when the steering wheel isn't set straight.My pictures/photos will return soon...
Key refuses to come out now!
So now I'm having this same exact problem but now that it's colder, the key almost refuses to come out of the ignition. The only time it comes right out is when I drive the car for more than a half hour and the car is completely warmed up. Sometimes, the key will only come out when I shake the shifter hard. It don't do anything when I press it forward anymore. I try pressing it hard forward everytime and I press it hard enough that it almost feels like I could break something so I stop pushing on it.
Any other ideas.
Post from the dead.
But I have this same issue. Car actually shifts into park.. but since the light doesn't illuminate it won't allow the key to be removed. The colder the weather/car is, the more often the problem occurs.
The only thing I can figure is that the pin inside isn't making a connection all the time to flip the actual light on. Or the wiring itself has a break or loose connection. Could this prevent the key from being removed? Or would it be better to check the transmission control unit?
