Building an Intake Manifold.
    is the intake port spacing on an h22a head the same as an f22b6?
    IF not, what would be closest?
    A straightforward answer would be appreciated.
    Yes, I am almost positive it is.
    R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
      Good to know. thank you.
        The port spacing is the same (or at least close enough) but the bolt pattern is totally different. Depending on your plans, that may or may not matter to you.
