ok for those that didnt know,i just bought my girl a cb and i had to do the timing.now the car runs but it s putting and really motor jumpy.it smokes white too.and the plugs in 1 and 4 smell like gas after the car is running and shuts off.is this good?thanks for the imput.by the way there is no check engine light.
91 accord plugs.
White smoke is coolant. A blown head gasket is a good possibility.
If the plugs smell like gas, there could be a number of reasons. If you have a blown head gasket, it's possible that coolant in the cylinder is hampering the combustion process, keeping the fuel from being completely burned. That would be my first guess, anyway.
If you didn't follow this thread, I'd go back and redo the timing...
http://www.cb7tuner.com/vbb/showthread.php?t=146242
Originally posted by xkjnboix View Postlol i pulled a cluster from a used car place and found many check engine bulbs non existant HAHA. bastards pull your egr or 02 sensor plug and start the car and c if u get a cel
Originally posted by jdmguy91 View Postthats normal. check ur timing is dead on. and ur 02 sensor. posibly ur egr.
My sentiments are ditto those of Deevergote. Sounds like you might want to do a compression test. If you have two cylinders next to each other with low pressure, that means the headgasket is most likely blown between those two cylinders. You are going to have to diagnose this farther, as a CEL won't tell you "Hey, I have a blown headgasket, fix me."
Open our radiator cap while the engine's cold. Take a sniff. Then, start the car.. let run for a bit, and go behind the car. See if it's the same smell. If so, head gasket! It is rather cold these days, so all cars are gonna throw white smoke until they're fully warmed up, and even if warmed up. Honestly, the car putting is most likely a spark issue. Plugs, Wires, even an ignitor. But yea, Deev's on the right track.98' Mustang 3V Swap
11' VW CC R36
Originally posted by 92smokeaccord View Postthe light comes on befor u start the car. and goes off when the ecu is done checkin all the sensors.h
do a compression check.
report back.
Originally posted by H22artman View Postyou're ACURA acronym is offensive. they might be honda's little brother but they still have the same blood....
report back.
well when I had a bad headgasket, my car was losing coolant. It wasn't smoking white though. So if you're losing any amount of coolant, then is most likely leaking into the combustion chamber.
Another symptom I experienced was a stumbling upon startup for the first 30 sec or so until all the coolant was evacuated/burned out.
Originally posted by 92smokeaccord View Posti know and sorry but as soon as i read it i laughed couldnt help it.and there more like our enemy then brothers.in my personall opinon...
MOPAR - more old parts and rust.
CHEVROLET - Cheap, Hardly Efficient, Virtually Runs On Luck Every Time
