Mysterious Electrical Wire??
    Okay. When I purchased my car... the previous owner did a few things to it that I'm not sure what their objective or purpose was. There's a white wire that is connected somewhere inside the engine bay(presumably the engine) to a spot up under the dash. I've a 92 coupe btw.. After starting the engine...and having the key in the on position.. I've noticed that I can turn the key back to what should be just Aux power..(1 position down on the ignition from started....makes sense??) and the car is still driveable and etc.. Only difference I can tell is that the if the car sits in this mysterious position long enough.. The blowers begin to blow the cold air..(or wahtever air is available outside...) meaning the engine isn't warming up the air anymore.. Kinda like if you had the aux power on with the blowers on ...
    Now if I turn the car off... And put the key in Aux position then the car is like normal.. It just turn on the radio and etc.. Not the engine and everything else.
    Hopes this makes sense.. lol
    Your car should'nt run in aux position. theres only one position that vehicles run, and thats the "run" position. I have no idea if this has anything to do with your mysterious wire, but its weird none the less. Some pictures of this wire would deffinitaly help figure out what it is.
      best thing to do if ur good with wires just put everything back like it should
      thats why i made a thread about engine wiring so it can help other people out
      but some pics would help
      WHEN LIFE PASSES YOU BY...DOWN SHIFT...
        hi i think it might be part of a remote start that was in your cb before
          Yeah it sounds like the remote starter relay/s are connected incorrectly.
            Well.. I'm not sure what to take a picture of... per se.. The wire is visible while looking up under the dash.. It disappears behind the vinyl..and it can be seen going out the bay through the space where there's the big bundle of wire.. It's too dark out now.. But at the high sun.. I'll take a picture of where it's going out in the engine bay.. (if i can find it..lol)
              What you're saying here is impossible. If the engine is running and the car has coolant, it's going to make warm air. Have you noticed if the AC fan engages under the hood when this happens?
              My first thought was that you had some sort of turbo timer left over ( they let the car run for a few minutes to cool off the engine and snail to prevent cooling too quickly). After considering it though, I think you have some other electrical problems. Trace this mystery wire and find out what it's connected to. I can't imagine one wire causing the problems you have, unless it was stripped bare and causing several different shorts.
