Balance Shaft Belt Removal Question!!
    Whats the easyest way to remove the balance shaft belt?? I want to do it but dont want to have to remove the crank pulley....Do I have to remove the bottom cover completely or can I pull it out of the way enough to just cut the belt???
    Thanks!!
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
    Thanks!!
    You must remove the crank pulley to remove the bottom cover.
      Can I just remove the bolts from the cover then bent it out of the way then cut it w/o removing the crank pulley???
        Why don't you just try it and quit wasting time typing?
        Just make sure that timing belt adjuster nut is snug before doing anything. You'll need a 14mm combo wrench.
          haha...im at work I work 70 hrs a week and only get to work on my baby on the weekends.....I don't drive it as a DD so shes at the house right now!!
          Plus I cant take my fucking wheels off yet...I lost the fucking Tuner Lug Key!!
          I was just wondering if there was a quick and easy way to do it...thats all!
            http://www.youtube.com/watch?v=mJUUyjJqk5A
            This is a video from EricTheCarGuy on how to remove tuner lugs without a key. There Ya Go!
            Now you can go take off the balance shaft belt! GET ON IT!
              lazy. your already choosing the easy way out by removing/cutting the belt w/o the shaft, how much easier do you want it to be?
              '09 Mini Cooper S (R56)
