So, I've been reading around about stock exhaust manifolds, and I had a quick question. I've noticed that the A6 exhaust manifold doesn't really get mentioned at all as an upgrade, because it is cast, but it is also 4-2-1 like the F22A4 header. Is there any known performance difference between the two, or is it just assumed that the A4 header is better because it is tubular? Anyone got any dynos of the difference by chance? I know it's not likely, but I figured I'd ask.
A6 Exhaust manifold VS A4?
The A4 manifold is the only difference between the F22A1 and F22A4... and the difference in power between the two motors is 5hp. Therefore, the tubular manifold is regarded as a "bolt on 5hp" mod. The A6 has a number of factors that give it the 15hp advantage over the F22A1... most of which are attributed to the IM, ECU, and camshaft. The exhaust manifold most likely plays a part as well, though.
Performance wise, I'd venture to say that they're similar. Nobody has ever done any actual testing to my knowledge, though.
