whats up guys i need some help, i was wondering if stock axels for cb7 fit on the h22 motor or do you need to get different kind of axels. If they do, do you think i should get the stock ones from autozone or is there any good aftermarket it ones.
axels question
If your doing a swap, I'am certain that you can use the Accord axles (same ones), but like leung said and I will also say it: Are you sure you wanna use autozone axles?
Originally posted by pedroalcala View PostIf your doing a swap, I'am certain that you can use the Accord axles (same ones), but like leung said and I will also say it: Are you sure you wanna use autozone axles?
I'm running Autozone axles myself. No problems so far (though one has never been driven on... not yet, anyway). NAPA axles have treated me very well in the past.
And yes, the H22 swap uses the Accord axles. This, as well as plenty of other very useful information, can be found in the "sticky" threads in the Swaps forum.
i hear more people saying their autozone axles going bad after replacing them once already then compared to other places like NAPA.
Well that's what i have on my car are NAPA brand axles which i only got for 60 bucks after giving them a core that i got at the PnP for 9 bucks for my 5spd swap.
compare the boot material that Autozone axles use vs. the NAPA ones and then tell me whats wrong with them. They're made of inferior parts. Great they've got a lifetime warranty. What if your axle boot breaks the night before you have work and its raining out? Oh but its okay, you've got a lifetime warranty. Try swapping those out 3 more times. That lifetime warranty bullshit gets old.
Either buy NAPA axles or OEM Honda ones. There's a reason why they last longer. The boots are made way thicker and are made out of a thick silicone and not just weak rubber that can tear much easier.
