my brother just recently purchased a cb with h22 installed problem is theres a vibration when acclerating when you turn left the vibration kinda goes away we've already replaced both axles and timing belt and water pump.car has coilovers on it and not exactlly level. it had homemade solid mounts in the rear and torque rod. i replaced the solid torque damper with a factory one because the whole car vibtrated like crazy. we seem to think its the motor mount on the driver side. any ideas? and its not a tire issue its coming from the drivetrain somewhere.
vibration while driving
Originally posted by speedracer450r View Postmy brother just recently purchased a cb with h22 installed problem is theres a vibration when acclerating when you turn left the vibration kinda goes away we've already replaced both axles and timing belt and water pump.car has coilovers on it and not exactlly level. it had homemade solid mounts in the rear and torque rod. i replaced the solid torque damper with a factory one because the whole car vibtrated like crazy. we seem to think its the motor mount on the driver side. any ideas? and its not a tire issue its coming from the drivetrain somewhere.
Check to see if the transmission was tapped. Is your H22 leaning to one side?
If they just bolted everything in without tapping a new hole in the H22 transmission (assuming they used it) then things won't work properly. You'll find yourself snapping axles.
ALWAYS make sure work done on someone else's custom car is done correctly. NEVER assume that they knew what they were doing!
Originally posted by deevergote View PostCheck to see if the transmission was tapped. Is your H22 leaning to one side?
I'm not sure what they used for the rear mount hadn't got that far yet but it is a solid mount.
