ok i wanna do a seafoam treatment on my car but im not got put any in my engine oil just in the tank and through the pcv valve hose into the intake mani my question is do i still have to change the oil cuz i just got an oil change
Seafoam
awww hehe! he talks like a baby!
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
I seafoamed my CB, but only put some into the intake manifold (brake booster) and some into the gas tank, since then I haven't done an oil change (1 month ago), but I highly recommend it. later
Originally posted by deevergote View PostSince you posted, do you care to help with the problem? Or was flaming in the Beginner Forums your only intention?
Seafoam works...just follow the EXACT instructions on the can...though I don't remember if it mentioned to change the oil on the can. Either way CHANGE is a must if you pour it into the crankcase...I...um left mine in sitting for weeks without realizing that's what I needed to do. So the end result of THAT was my F22a1 funkin up! Bogging horribly into every gear I shifted into.
Lesson learned right? lol Nope...I still haven't changed the oil at that time and then poof! I had engine overheating issue.........yea..not fun. Anyway GL Kispirit!
*Oh yea and if you put too much into the gas tank....it COULD eventually give your O2 sensor a beating. Follow instructions...if you do, you're safe...like sex and a condom!
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
I just did an oil change and i want to do a seafoam treatment on my car. but i dont wanna put any seafoam in the crankcase. just in the tank and in the intake manifold through the pcv hose. if i do that do i still have to change the oil. ..........................is that better understanded for those who cant understand quick writing a.k.a(baby talk)
I'm not exactly sure, but I don't think that the O2 sensor will be the point of failure from too much fuel additives. The rubber parts in the fuel system are usually the point of concern, as most additives contain heavy doses of alcohols which play hell on rubber, i.e. fuel injector o-rings. It would still take a lot of alcohol to cause damage though. Most vehicle manufacturers allow up to 10% without worry.
And, you should be fine for as far as oil changes go by only treating the intake and fuel system.Last edited by nblanton; 12-01-2009, 04:36 PM.
