New radiator fan doesn't turn on
    Hey
    Ok my old fan broke into pieces...damage my radiator.
    I replaced the radiator fan and radiator.
    Now the fan doesn't turn on.
    I turn on A/C and only condenser fan turn on. the other doesn't
    I double check the connector and it is good
    Could it be the relay that is broken?
    Put 12V from the battery to the fan leads first to make sure the fan works, then troubleshoot from there. Turning on the A/C won't automatically fire up the cooling fan. That is controlled based on engine temp, you live in NYC so that fan may not turn on till next Spring
      Turning on the AC does force both fans to run.
      My 5.7 LS1 Holden Ute
        yes, this is true.
        You may want to see if there is a fuse for the radiator fan.
        http://www.cb7tuner.com/vbb/showthre...=1#post1823428
        My Custom BB6 Dash Swap Thread
          My bad, I'm completely wrong. Yeah, check the fuses first (#15 and 39 under the hood, both are 15A) , followed by the relay, fan motor, and A/C diode last. Page 16-107 in the FSM.
          I was going off how EF fans are controlled from memory and posted before I checked. Sorry for the b.s. info.
            oop. I just saw cooling fan fuse. 20A right above cooling fan relay.
            the fuse is good.
              Fuse and Relay is good
              I switch the fuse with other 20a
              and I switch relay with the power windows.
              Power windows work with the cooling fan relay.
              I think i got a bad fan. I'm going to jump the fan to the battery and see if it will run.
                That's what I was going to suggest... give it direct power and see if it runs.
                  I jump it directly to the battery and it turns on!
                  What is next?
                    Are you sure that you have the right fuse? It should be a 15A, not a 20A. The locations are #15 and 39 in the under hood fuse box.
                      I'M AN IDIOT! LOL
                      i look at the wrong fuse!
                      the fuse busted. New fuse fixed it
                      thank you everyone!
