My starter has took a dump hardcore. Took it apart today and the insides were toast. I was needing to know if I could go the the JY and pull any starter off of an F series motor and will it bolt right up. Thanks in advance
Starters
Starters
The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)Tags: None
I can't swear to it, but you will probably be okay. I would take the old one with me, and compare them. You can check rockauto.com to see if they have brushes to rebuild them. These guys definitely will:
http://www.nationsautoelectric.com/
The part listing for you starter can be found here as well, so you know what parts you need to order:
http://search.waiglobal.com/vehiclelookup/
Rebuilding yourself is pretty rewarding and often cheaper and of better quality than aftermarket. Usually, you can rebuild as long as you don't have the commutator worn too bad and no shorts in the rotor windings.
Those links were helpful, I am deff going to rebuild my starter from the looks of it the starter off a F is similar to the H, so all i would need to do is swap the insides to them and we should be good to go....The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
