compression
    compression
    How hard should it be to turn the motor over by hand?
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    that depends on whos doing it.. no but really im assuming you took the plugs out? otherwise... not real easy on a compression stroke...
    93 cb7 ex coupe
    Granada Black Metallic
      I had one plug out and to line the motor up at top dead it wasnt very hard.. which kinda has me woried i mean i know its no high compression racing motor but..
        should be easy till just before tdc on the compression stroke of that cylinder...then it gets a little tough, then it rolls over almost on it's own.
        You should be able to do it with a regular length 3/8 ratchet it should not require a long 1/2 breaker bar.
        normally you're actually turning two compressing cylinders, you were turning one. With the plugs ALL out...super easy
        sounds like you're fine.
        ____
          okay cool thanks guys
