don't use speaker wire. at the very least use 18 gauge automotive wire from autozone. i used an old power cable from a computer to splice into the O2 sensor as it has a thicker plastic shielding to protect the wires from heat. good luck
Factory Header
Originally posted by 93.4dr.22A1 View PostThe HP gains from the paint arnt enough for the work, it aint gonna last long either so, im gonna leave it.
But would like to know about the gasket thing, See that stock Honda exhaust gaskets are like little round tin pieces. On the header to DP,DP to cat, cat to IM pipe. I have some high temp gasket material, its not mettalic, but should I use it?
And I have to lengthen my O2 sensor to relocate it to the new spot behind the motor. I noticed the wire strands are not like speaker wire, but can I safely use speaker wire or is there a better type?
HP gains from the paint? your not serious right?
93 cb7 ex coupe
Granada Black Metallic
yea exhaust is pretty much done, had a little bit of work to do for repairs on the whole system. Really wish i could just afford a lil 2.25 pipe, but not right now. So i've replaced the demolished resonator with a straight pipe, few other spots had to be fixed.
But the header is on and so far all the way back to the tailpipe its all sealed up. I'll get some wrap as soon as I can afford it, probley around the time I get my new exhaust.
well got everything done, and its great. I can actually hear myself think while driving.
But was kinda curious on how much of a shift in the power range I will notice. I havent taken it out for a freeway cruise or anything, I just made it into 3rd, but it seems like i've actually lost power.
With the header I should lose some low end torque right? but gain in the top end?
