Lower ball joint
    Originally posted by Leung View Post
    I removed the knuckle and took it to a buddy at Midas to press out the old and the in the new one. He only charged me 20 bucks.
    I think this is the best option for you. If you know how to get your knuckles off you are good.
      I just completed this job a few weeks ago. As mentioned before get the loaner press from autozone and ask for the honda adapter kit for the press. The honda adapter kit has a special offset which allow you to position the press and align it properly to push the BJ out and press the new one in.
      93 SE Coupe
        3-7
        you have to remove the axle, unbolt the hub, pull the hub out a little to all the way. I removed the entire knuckle.
        hammer out...press in...do not hammer in.
        Go with OEM, don't cheap out...honda OEM from the dealership...not expensive at all.
        majestic automotive.
        ____
          What you consider difficult and what others consider difficult will vary significantly.
          Look up how to do it, and if it looks too hard for you, pay someone to do it for you.
          x2
          its all about how knowledgable you are. if you arent sure how to do it, you should probably have someone help you.
          R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
