Bad EgR?
    Bad EgR?
    So i think this problem is more common on the automatics..but heres the problem.. 91 accord lx f22a4.. when u drive the car and its not up to normal operating temp..sometimes when your accelarating..if feels like ur driving a stick and u missed a shift..the car wont go faster until you let off that gas and punch the gas back down..also if your driving at faster than 45mph the car sometimes stumbles and doesnt wanna go faster..this keeps on goin until the car reaches normal operating temps and the CEL comes on..after the light comes on the car drives perfect.. i pulled the codes and all i get is a IAC valve code which i kno its bad cause it doesnt idle in park or neutral..but i dont think a bad IAC is the cause of this weird lag when the CEL is not on..Ive heard that this might be cause of a bad EGR going bad and the intake runners on cyl #1 and #2 getting tons of carbon buildup..
    Any one familiar with this problem? Im gonna test the egr on the car tomorrow its just too cold to go look for my vacuum pump right now.. thanks for any help
    i really think you should at leastattempt to clean the IACV because that will cause driveability issues.
    if the egr is open at idle it will cause a really rough idle but off idle it will be okay.
      whats the best way to clean it out as well as most effective? ive heard theres a way to bypass the iac system ..how do i go about doing this and how will it affect the car pros/cons
        SinCityCB702 I had the same problem at the beginning in F22A3 MT Acc. (ecu code 12! - problem with EGR system as I remember )
        - I've cleaned it(EGR) as IACV and Throtle Body and bought new gasket - didn't help
        - Buying "new" VCB box solved the problem and ecu code 12
        My first car my first ride
        http://www.cb7tuner.com/vbb/showthread.php?t=148674
        My Polish Ride + Meetings pic
        http://galeria.h3m.pl/main.php?g2_itemId=27303
          shit lol that doesnt sound cheap lol.. i guess ill still try cleaning them out before puttin some money down lol tight budget right now lol..vcb is the box on the passanger with all the vacuum hoses run to correct?
            - DIY IAC cleaning. The object/target one for all (IAC/Throtle/Egr/...) - clean shit from inside!!
              correct
              bought mine for 10$
              check ecu codes? any check engine problem?
              try to clean first
                i pulled the codes when we barely got the car.. i cant remember the actual codes i know for sure one of them was IAC though.. that and another one for a vacuum leak..which i fixed that one already.. ill check again tomorrow and see whats codes is throwing at me before i get started... oh nice write up by the way..
