short shifter question
    hey guys i need some advice, i really want a short shifter but i have herd that they mess up the tranny, is this true? i was thinking about the neuspeed shortshifter. does anyone have this on there cb and if so, how has it worked out for you. im not sure if it matters but its forr the h22 tranny
    http://www.cb7tuner.com/vbb/showthread.php?t=194049
    Its the driver that screws it. I had one in my old 92 didn't mess anything up
    Bought From
    Tommi
    RiKan_BoY86
    current s2k fund... $200
      im not gonna lie i drive my car hard somtimes, and i race alot in the summer with all my finds and idk if i should put it in
        If your having second thoughts don't do it
        Bought From
        Tommi
        RiKan_BoY86
          im not second thoughts i jus dont want to fuck up my tranny, i drove my boys integra yesterday and he had a short shifter and i liked it alot
            try this, if you dont like it.. put it back to stock.. http://www.cb7tuner.com/vbb/showthre...t=lowes+racing
            93 cb7 ex coupe
            Granada Black Metallic
              i have this short shifter installed on my car at the moment. i have to sday it is fantastic! it does rub on my center console when im in fifth or reverse. it is awesome and takes about 5 mins to install.the throw is about 25% less or so
              Originally posted by Quashish
              Holy crap thats a clean F series. jellish mang.
              Quashish dictionary
              Jellish: (adjective) Jel-%i'sh+#
              To envy something to point of almost blowing a load involuntarily.
                I wonder if having a oem lude shifter is as short as a aftermarket shifter for a cb.
                  No, a short shifter puts the cables in a perpetual "partial shift" state. This does result in greater wear on your synchros. If you don't plan on having the car for all that long, then perhaps it'd be fine... it'd just end up being the next owner's problem.
                  Short shifters also tend to make shifting very notchy. I can shift faster with a smooth long throw than I did with a short shifter.
                  The Neuspeed adapter works well enough... though mine always came loose. Not good when your cable pops off on the highway as you're merging, and you're stuck in 2nd gear.
                  The $3 Home Depot DIY bracket is actually probably more effective. It's fastened more securely.
                  I currently have a modified OEM shifter that has been shortened AND had the cable mounting point relocated (as this is the ONLY thing that a short shifter does... simply moves where the cable attaches). I have it back to stock, and I prefer it that way.
                    this makes sense to me, however is there any proof of this?
                    93 cb7 ex coupe
                      My transmission.
                      Look at the way our transmisions work. The cables more levers on the transmission, which manipulate the transmission internals to shift gears. When you shorten the throw, you're making it so the one cable is always partially moved toward a shift position... if that makes sense.
                      Like... normally, you shift from here |-----| to here
                      Shorten it, and you're doing this --|--|
                      You're not changing the internals... so you're just changing the distance that the cable and shift lever move.
                        My transmission.
                        and again it makes sense, but.. if all ur oing is mving the cable higher on the lever, the pull or push of the cable has not changed.. only the difference in the length of the movement..
                        93 cb7 ex coupe
                          i just did this DIY and i must say its a great deal i would go with this over a differnt shifter
                          Out of a job yet? Keep encouraging people to buy American. 500 of the biggest, most profitable American companies make more than half of their profits overseas! You Jackass!
                            I'll have to come back and explain how I'm picturing it in my head... when I'm not running on 3 hours sleep and 16 hours of work...
                              ok.. get sum rest, cause im really intrested in this...
                              93 cb7 ex coupe
