im stumped getting cel code #5
    im getting a cel i pulled the code and i get 5 quick blinks then it goes off for a while then i get another quick 5 blinks.
    http://www.cb7tuner.com/vbb/showthread.php?t=21259
    that link tells me it is 5 MAP - manifold absolute pressure sensor
    edit:
    just saw the abbreviation ill try to search it that way
    New & Improved 93 Accord EX Coupe
    what makes a man a man?
    Originally posted by ric3rboi23
    disrespect females, acquire currency.
    still stumped, has anyone gotten this code, and if so did u just replace it or what. any info would help
      the map sensor is in the black box on the fire wall.u nmight have to replace the whole box to clear that light.let me guess the car is putting at an idol?
      my new turbo build
        its surging at 1.3- 1.5 rpm
          I just sent you a text man.
            no vac leaks?
            I <3 G60.
              OBD I - "5" . MAP Sensor Open or shorted signal circuit
              newer models
              "5"
              Accord
              85-98 *
              MAP Sensor (Manifold Absolute Pressure)
              mechanical problem / disconnected piping
              * exc 94-95
              My first car my first ride
              http://www.cb7tuner.com/vbb/showthread.php?t=148674
              My Polish Ride + Meetings pic
              http://galeria.h3m.pl/main.php?g2_itemId=27303
                i had a code 5 for the map and replace the sensor. before i did i had a crappy idle and HORRIBLE fuel mileage. the mileage got better but its still not the best tho (20mpg's). also i cant get rid of the code either. i pulled the ecu fuse and everything.
                  just stating i still have this issue, i eliminated the whole black box set up and used the h22 map sensor on throttle body and i still get the code, we ohmed out n checked connectivity of sensor and its good but still throws check engine light, if the plug in is good with map sensor what else could be wrong with it.
                    unplug, check 5 volts and good ground at the connector with key on engine off.
                    I <3 G60.
