Hey guys lately ive been hearing a noise coming from my valve cover around the spark plugs. I checked the spark plugs and checked the wires. What else could it be. I am also getting some oil leaking around the valve cover and it smells like a drifting competition in which someone blew an engine after I stop the car. Anyone know what it could be>?
noise in engine around spark plugs
I don't know about the noise but, your valve cover gasket need to be changed.....change that and you will not have oil leaks around you valve cover gasket.....later.
Originally posted by pedroalcala View PostI don't know about the noise but, your valve cover gasket need to be changed.....change that and you will not have oil leaks around you valve cover gasket.....later.
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
Originally posted by deevergote View PostMake sure your timing belt isn't getting oil on it... that'll make it snap real quick.
What sort of noise are your plugs making? I had a plug being pushed up out of the head, and it made a horrible knocking noise.
Rush
Originally posted by deevergote View PostBe sure not to over tighten. The aluminum of the head is fairly weak. That was my problem. I overtightened and damaged the threads.
It could be your valves. You might want to do a valve lash adjustment at the same time as the valve cover gasket.
Rush
Originally posted by cb7rush View PostI had a feeling I had to replace the head gasket. Thanks.
Originally posted by ch33.thao View Postit could be your vaccum have to check that. also is your car burning oil?
Rush
Originally posted by pedroalcala View PostYou mean valve cover gasket LOL
Rush
