reverse lights dont work
    my reverse lights dont work. i checked all my fuses and taped up any exposed wires. does any1 know what the problem could be?
    You check the bulbs?
      if your car is a stick, then it could be the reverse switch. Located on the top of the transmision, to the right of where the radiator hose passes over the tranny. repair book has pics, and quick test, which you just test the continuity of the switch, in reverse and a other gear.
      Mine just went out, thats how i know all this.
        correction its located to the right of the passenger side motor mount, not the rad. hose. Sorry
          ^^^ That was my problem the switch. if its not the bulbs more than likely its the switch.
          Freedom Is Not Free
          U.S Army 02/08 Medically Discharged
