does a h23 have a knock sensor? what about a oil pressure sensor? where are these sensors located. my h23 is leaking oil right under the oil filter. I'm guessing its the oil pressure sensor because there is a small screw.
h23 sensors
Originally posted by kamikaze_accord View Postdoes a h23 have a knock sensor? what about a oil pressure sensor? where are these sensors located. my h23 is leaking oil right under the oil filter. I'm guessing its the oil pressure sensor because there is a small screw.
Originally posted by fstacrd View Postkamikaze you got it backwards the knock sensor is right under the head on the back of the block ubove the oil filter the one under is the oil pressure sensor.... just thought id correct you on that.......
