Tranny wont line up
    Tranny wont line up
    Ok as the title states i cant get the tranny to go back onto the motor..
    Any tips/hints/tricks?
    edit: 5 spd f22 and f22 tranny
    yes i did a clutch but the tool is suppose to line it up...
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    5speed or auto if five speed and u did a clutch u probably didnt line it right that could cause the tranny not to line up
      It would help if we knew what motor and tranny you are doing?
        added info to the post sorry
          did u leave it in it and tighten the bolts or did u line it up then took it out and then tighten the bolts up
            left the tool in when we bolted the pressure plate up.... ill try checking clutch alignment tomorrow during the day again.
              Get someone to turn the crank as you put the transmission back on. The splines aren't lining up, and you're never going to get it in otherwise. I spent 3 hours with cpmike trying to get mine back in. We finally realized what was happening, and got his mom to come out and turn the crank... it was back on in 5 minutes. Just a very slight turn is all you need.
                or if u cant get some one to help u.u can muscle it like i did.get in the motor bay,stand over the tranny bear hug it lift,push and turn at the same time.it will just slide in.this was my way of doing it because i had no one to help and i couldnt wait.good luck.
                my new turbo build
                  If the splines aren't lining up, and the shaft is in contact with everything, it will simply turn as you turn the transmission. You need to be able to turn the crank.
                    maybe i got lucky.but it worked thats all i care for.
                    my new turbo build
                      tranny wont line up
                      the cluch might not be alighned properly..
                        I got some good ideas now on what to look at when i get back in there
                        thanks guys ill let you know how it goes
                          Use an alaignment tool first. Then as deevergote said turn the crank on the motor slightly then reposition yourself to alaign the transmission again.
                          If it doesnt work try ,try again once its done alaigned in the spot get a jack underneath it to hold it in place so that you can bolt it on there. goodluck and be patient.
