P28 or not?
    P28 or not?
    How do I tell if the ecu I am looking at is a p28 or not?
    read the tag?
    smoke tires, not drugs.
      sounds about right.
        where is it located, on my ecu i seem to not be able to locate it.
          here is a site that might help you www.hondadata.com/techecuid
          There should be a white tag on it, looks like 37820-p28-a01
          The middle three are the numbers that are most important to you.
            Keep in mind you cannot use a stock P28 on your car.
            Since you don't know how to identify it, I seriously doubt you know how to modify it...
              Or, if the tag has been removed, you can remove the top cover, where the plugs are, on the black plastic inside, it should say what ecu it is
                I did not know that thanx!
