jumpy idle after p12 install
    put in a p12 yesterday. Im glad with the results however my idle
    seems to jump around or hover at 1.5k ? Sometimes it sits at 800
    like it should but too often it's doing otherwise.
    is there a quick fix for this?
    On the right hand side of the intake manifold you'll find the FITV ( I think, it could be the IACV, I confuse them) open it up, inside should be a whitish plastic disc with slots in it. Turn it clockwise until it's snug, put the top back on and start tha car. It should take care of it. I had the same issue with my p12 installation.
      More often, the issue is the IACV, which is the component in front-center of intake manifold with electrical connection. The FITV is to the right of that on F22ax IM and under the TB on H23 IM.
      Read the "base idle" setting procedure I created and follow, it is located in the stickies of DIY section.
      If you can not set the base idle via my directions, then move forward to FITV being potential cause. You can do what is mentioned above for the FITV fix, but the key is to remove the FITV top cover after the engine is fully warm. Then, snug up the white plastic ring with flat-head screw driver using the slots in it. Shut down the engine, clean the top of FITV body or degrease, apply silicone to seal cover upon reinstall. Finally, redo the base idle procedure previously mentioned to set everything appropriately.
        awesome, appreciate the replies!
        ill get on this tomorrow after school
          just swapped for a p12 myself about a month ago and i hadnt gotten around to checking it out, but now that i know ill just go and take care of it tomorrow... Thanks for thread and help! haha
