Cheap ebay headers
    Originally posted by Accordlakeville View Post
    I heard that Ebay headers work but they tend to crack later down the road. Is that true fellas?
    They work in the fact that they take the exhaust from 4 cylinders and merge it into a single pipe, yes. But for a performance gain? Not really. Not the cheap ones. A cheap $100 header will get you about 3hp. MAYBE. To make power with a header, your only real option is the Bisimoto header, which makes 27whp on a stock F22A1... it'll make more with other mods.
    And yes, the gaskets that come with the cheapies are often garbage. That increases the cost of the header, since you have to buy new gaskets. Additionally, if you've already installed it with the gaskets it came with, that means you have to take it apart and do it all over again. If you're paying someone to do it for you, then you're really screwed!
    As I've said... if you need to replace a damaged or missing OEM manifold, then the header will work. Though I agree that a junkyard piece would be the most effective way to save money. You will not use a header for turbo... so spending $100 on a header is a waste of money.
      i live in kentucky, no junk yards where im at, would have to travel 100 miles to nearest one with honda parts. this is why i want the header off ebay. thanks for the responses guys..
        OEM manifold off of ebay?
        I just hate to see you spend money on something that isn't going to help you in any way... and it'll just hurt your savings as you build your turbo setup.
          where are you in kentucky? i think i have an old DC laying around that you can have. i will have to check though.
          '91ex coupe, modified.
          http://www.youtube.com/watch?v=sP0JsF__KzA
          @ConaireSmith on twitter
            Originally posted by F22HB View Post
            imo the bigger problem with them is the quality of the gaskets.
            and straightness of flanges.
            I <3 G60.
              Do you guys think that there is a difference in quality between a $70 ebay header and a $100 one?
                i'm pretty sure there are only 2 different ebay versions, one is almost a copy of the a4 manifold and the other looks like it has longer primaries. as far as price goes, you might as well buy the cheapest one you can find, because it's (most likely) going to be just fine.
                96 mx-6, needs work...
                91 accord lx sedan, needs work...
                  Sorry guys, i should have clarified it better, i need all the way back to the flex pipe, everything from the cat forward.
                    I've been running my ebay header and downpipe for about 3.5 years with no problems until recently the flex pipe shredded. I think that has more to do with my motor mounts being worn though. Waiting on another $70 one right now.
                      Last time I bought one the got the head and downpipe with flexpipe so you should be good
                      Life's a garden. Dig it.
                        Ive never actually used an ebay header before but maybe I should since im hearing decent reviews here.
                          i liked my megan header. I felt a decent difference. definately noticed a mid range gain and this was the last addition (along with hf cat) after i already did catback and intake so the header might have been the choking point. If you compare the cast manifold with any ss tube header, its definately easy to see how one would flow much better than the other. are we still taking this manufacture dyno claim of 27 whp to heart?
                            Thanks for all of the input guys,(off the subject) i got my clutch and flywheel on today and connected the tranny. Is it normal to be able to turn the crank bolt to crank the engine over and the tranny not stop it when you put it in and out of gear. None of its in the car yet. I didnt know if there was enough pressure on the clutch disk yet to stop it from turning with the engine. It almost feels like the tranny is in neutral no matter where i put the shift arms.
