Rust spots
    Rust spots
    Anyone know of a spray I can use on minor rust spots to eat out the rust and/or prevent the rust from spreading. I don't want to do the sand, prime, paint method. Just a simple spray on a few small spots here and there. Is there such a thing?
    91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
    Neuspeed Super Cup Kit (7/2010)
    TAS rear drum-to-disc conversion (6/2010)
    Above photo taken - 4/2010
    you can spray rust converter on it and it will convert it to black primer.
    it will probably continue to grow though. rust usually comes from behind the panel when you see bubbles. later.
    Avoiding dirt at all costs
      There is only one way to remove rust, that is to remove it. None of the rust to primer or spray on over the rust paints actually stop the continuation of steel oxidation. Sure they last long enough to sell your car and that's about it.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        If you want to just paint over it (if it's not that bad), use POR-15. I used it on my old EG and my winter beater, it works well. http://www.por15.com/whatispor15.asp
        Hope this helps!
        life is good.
          yea i got rust in the rear wheel wells like always
            Rustoleum FTW! lol
            BTW, this is in the wrong section. Technically.
            R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
              Rust
              I hate that my car has cancer
              Originally posted by visualpoet
              some owners think it's the best thing since titties
