Turbo manifold question
    will the h22a1 turbo manifold and down pipe work with a h23a1 motor???
    I don't think so.
    I think(not very sure here)... that the H23 is compatible with the F22ax, and if so then it is also compatible with the turbo manifold of the first gen DSM(Eagle Talon, Chrysler Laser, Eclipse GSX).
    Though, I'm not so sure. So someone might have to back me up on this or correct me if I'm wrong.
    Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
    Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
      0_00_0 = H22 exhaust port design.
      0_0_0_0 = H23 exhaust port design.
        No, a manifold for an F22a would work though.
        R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
          Originally posted by shadowdlink View Post
          I don't think so.
          This is correct. The DSM manifolds work.
            with little modification to bolt pattern.
            do not forget to mention that.
            DSM is not a direct fit.
            MadLab Racing
            Southern Maryland
              Wrong man.
              0_00_0 = f22Bx exhaust port design.
              0_0_0_0 = F222Ax, H22Ax H23 exhaust port design,
              The H23 (NonVTEC) and the FF22Ax are the same, The H22Ax is its own animal.
              750 WHP/575 TQ CD5 Raping a street near you....
              realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
              GFI HOLLA!!!!!!
              http://www.youtube.com/watch?v=Cdiz0k0Rudw
                Originally posted by Supergenius View Post
                Wrong man.
                You just said the f22ax, h22ax, and h23 are the same port, then go on to say the H22 is it's on animal?
                Current 2016 Ford F150 XLT Sport
                Past 1990 Accord EX Sedan
                Past 1990 Accord LX Sedan
                Past 1991 Accord LX Sedan
                Past 1993 Accord LX Wagon
                Current 1991 Accord EX Wagon
                  Yup. Its true...
                  Think about it... The DESIGN is the same (Port orientation.....O-O-O-O, vs the F22Bx O-OO-O)... the SPACING between the evenly spaced ports is differnt... (between the H22A and the F22AX/H23)
                  The H22 has thee same non-siamesed middle port configuration as the H23 and F22Ax, but its Not spaced the same.. Nor the same as any other H motor pattern, hence its OWN animal.
                  Simply put you can use a NonVTEC H23 manifold on a F22Ax and vice versa, but neither will fit the H22Ax/H23VTEC Head. Its CONSIDERABLY off. Just because the ports are evenly spaced doesnt mean that space is the same as the H-series VTEC Head
                  Caspiche???
                  GFI HOLLA!!!!!!
