Originally posted by bcjammerx
View Post
swiss box mod?
Originally posted by deevergote View PostOr you could have emailed me to fix it for you... now you're breaking the rules with 2 accounts. Had I not seen this explanation, I'd have simply IP banned you for having multiple accounts.
Originally posted by deevergote View PostHe wants to stay stock-looking under the hood. A cone filter on the end of the plastic tubing won't really do that for him.
get it guys? this is what im asking.. looking as stock as possible while gaining HP... what is your input?
People are helpful here, but many are overzealous and tend not to read the whole thread... or even the whole first post. Of course, MOST of the time, we get noobs on here asking the exact same questions over and over again, so it's a knee-jerk reaction to just throw down the usual reply!
The only header that really gives any worthwhile horsepower gain is the Bisimoto header... and that work of art won't be hidden under any stock heat shield. The cheap $100 DC Sports knockoff headers on ebay will get you maybe 3-5hp. For a stealth look, that's pretty much all your have to work with, unfortunately. Don't bother spending $300-$400 on anything else... those more expensive headers don't help much more, and you're just paying for the CARB sticker (which, if you're not in CA, doesn't matter).
Another option is to approach ESP (Explicit Speed Performance). They could make a custom header that would give better gains than any other cheap option, and they could probably make it to work with a stock heat shield. It won't be dirt cheap, but it will give more than 3-5hp I'm sure.
If you can find an Unorthodox Racing pulley set, including the crank pulley, you'll see some gains there as well. They're not 100% stock looking, but anyone who doesn't know what they're looking at probably wouldn't know the difference. UR doesn't make F22 pullies anymore, as far as I know. The crank pulley is the one that gives the most power. I would not suggest going with a knockoff brand, as that could destroy your engine if it's not properly balanced (the UR pullies have even been rumored to destroy oil pumps... though mine has been good so far, for the past 7 years.)
cai tubing with flat black paint or that paint for metal parts that gives a hammered metal appearance or bubbled look...that'd look mostly stock...the filter would be in the fender so you wouldn't see it. or you could cut the stock tubing to wrap around itI kid on that last part there.
OR
cone filter IN the air box...connected either to stock tubing or above idea...open the end of the intake box after removing those two small tube and removing the resonator box...as it is it has two small openings for the tubes going to the intake resonator.
If you want to keep stock looking but actually gain some measure of performance...at least put a cone filter IN the box...
Obviously you would need to mod the box to accommodate and hide the cone filter, say lowering the opening where the intake tube connects to the box (so that the cone will fit on the tubing IN the box)...but make it so the stock tubing doesn't just connect to the box but actually goes INTO the box...and opening one end of the box to let more air in.
dammit...now I can't stand the word "box"____
Just to touch on the common belief that cutting holes randomly will increase flow. That is not always the case. Air and water flow very similarly. By cutting holes/altering the airbox, you can actually disrupt that flow where you hurt performance.
Air flow is all about physics. There's a lot more to it than most people think.
Hey Gasser I'm looking to do the same thing until I can find an H22 or H23 to build and go all out with it. This is a link where you can use stock parts from other Hondas to gain HP.
http://www.cb7tuner.com/vbb/showthread.php?t=88154
Maybe use a K&N flat filter in the air box and punch some holes where you feel it will give you the best air flow but remain out of site for the most part and you should, according to others on this site, gain some HP and retain your stock look.
I'm fixin to do this cuz it's cheaper while I learn how to make serious HP for a jap motor. Can get 700 + hp from a bowtie easy. What I wanna do is get 400hp from a honda in the long run.LIVE FREE OR DIE
