92 f22A6 one or two o2's?
    I have a 92 f22a6 engine and ecu, but not the wiring harness for that engine.
    I've used the wiring harness from my 92 f22a1 engine, which uses one o2. Question is, does the a6 use one or two 02's ? from what i hear OBD1 means 1 02 and OBD2 means 2 o2's. The reason I ask is i got an intermitten code the other day 41. Does'nt that mean 2 o2 sensor? Im confused and would appriciate some help.
    there is ony 1 o2 sensor. the only thing u have to do is wire the iabs on the intake manifold.
    my new turbo build
      yes i did that. It was easier than figuring out this damn code 43! lol...
      Car runs great even after this code trips. the only symptom i have is while engine is warming up from cold, if i put car in reverse from park than back to park it idles up and down till it warms up. I've looked at the stickies on hear for eacv for cleaning and done it. other than that it runs great. I have a new o2, its bosch for $50 bucks. I hear that i might have to purchase one from dealership? Anyway thatnx for ur help.
        43 Fuel supply system
          yes code 43 is fuel supply system. And i have done basicly everything possible
          to figure it out. Thank god my car runs fine even when the code trips.The only thing i have'nt done yet is get a o2 from dealership.
            you don't have to buy one from the dealer, just look for an NTK from online dealers. at least i think it's NTK for the o2 sensors.
              Just don't get a knockoff that was made to look like an NTK (or NGK... or Denso)
              ALL CB7s are OBD1 (none are OBD0, and none are OBD2). All have just one o2 sensor.
              And yes, that Bosch sensor will not work correctly in most cases (some people claim to have luck... most do not)
              Get the proper o2 sensor. It is going to run you about $150. I've heard of people getting lucky and finding them for $80... but I'd be wary of cheap knockoffs... they DO exist. Paying another $80 for yet another part that won't work, on top of the $50 you already spent, isn't going to be a good thing.
                Purchased an o2 from my local honda dealer today. Still have code 43. Just for shits and giggles I swapped ecu's and still code 43. Tomorrow im going to check map sensor ect. Thing is that my car runs great even when code is on.
                so im happy for that.
                  so NTK and Denso are good?
                  Yes my name is Dang, Don't use in vain
                  1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                  1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                  2008 Honda Accord EXL (Coupe/SanMarino/6spd)
                    Yes, those are the brands that work properly.
                    That's odd that you still have the code. Most actual fuel system problems would usually result in noticeable behavior.
                      I need a new EX O2 my gas mileage sucks
                        Got mines from autozone the other day and it was $80 for the PnP Bosch and took off the check engine light. lets see how long it will last........have 1 year warranty....
                        Links to my rides :
                        1992 Accord EX*
                        1990 Accord EX
                        1991 Accord SE (4th)
                        1991 Accord SE (3rd)
                        1991 Accord SE (2ND)
                        1991 Accord SE
                          Yeah my o2 is good the wires I traced back, no shorts. Pretty much stumped on this one. Im gonna look in my local junkyards for an a6 wire harness. Some of my plugs on my old harness are getting beat up from all this testing. Iv,e read in some threads where it was a gasket leaking. so maybe i will purchse a gasket set for intake ect.? I took back my old o2 to schucks told them it was no good. The guy ask where the box was. I said its the o2 that has the warranty on it not the box! He was acting like i was trying to steal something!
