Valve Cover Gasket Questions...
    just watch when you tighten the top bolts that hold the cover down cause i broke mine and had to do a whole mess with it a 30 min job turned in to a 2 day job lol....
      Wow, did you read any of the dozen or so posts above? Almost every single person said do not over tighten the valve cover nuts...
      Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
        That put him at 29 posts....................
          Oh.... now it makes a lot of sense why he posted a whopping six words in this thread.
            Oh well someone will notice it and take action if it keeps happening.
            Op there's also going to be 8 o-rings that you'll need to replace. 4 of them are up top and 4 down below. The gasket set that I got when I did mine only came with 4 so you may want to make sure the set you're getting has all 8 plus the valve cover gasket when you buy it.
              I think it's the Felpro sets that come with the VC gasket and all those other o0rings that the last few people were talking about, if you go to Honda, everything is sold individually.
                down below? like where the spark plugs go? i never knew that. how do you get the old ones out?
                2013 Ice Cream Cruise!
                VIDEO: 2012 Ice Cream Cruise
                VIDEO: 2012 Ice Cream Cruise part 2
                The single largest cruise in the Midwest!
                August 3 ~ Omaha, NE
                By 1320 Video
                Member's Ride Thread
                  Here you go sir.
                  http://hondatuning.info/accord-f22-s...l-replacement/
                  That site has vacuum diagrams and a bunch of other stuff so you might to look around just for the hell of it.
                    Here you go sir.
                    thanks dude, thats awesome! new bookmark!
                    By 1320 Video
                      No problem
                        OWNED!
                        Yea, the gasket is easy to do. Just make sure it's on straight all the way around the valve cover before tightening it down. And even though it's been said many many times already, DON'T OVER TIGHTEN THEM! USE A TORQUE WRENCH!
                        Also, a valve adjustment would be ideal while you are replacing the gasket like drummersteve said.
                        Here's a good step by step for the procedure. It's more for a V type engine and not an inline engine, but it's basically the same concept.
                        Valve Adjustment Procedure
                        1. Valves can be set on a hot or cold engine. A cold engine is a lot more comfortable to work on. Major camshaft manufacturers recommend setting valves cold, to avoid erroneous adjustments on lifters that may be "pumped up" If you are setting valves on a fresh engine that has not been run, everything should be well lubricated before you begin.
                        2. Remove both valve covers and remove the spark plugs to make the engine easier to turn over. Also, If you are setting valves on all cylinders, it is generally easier and less confusing to just loosen all of the rocker arm adjustment nuts before you begin. This also allows for all of the internal lifter plungers to return to their "home" position.
                        3. Using a long handled ratchet or breaker bar attached to the crank bolt, turn the engine over in the clockwise direction.
                        A. Starting with #1 cylinder, turn the engine over until the exhaust pushrod just begins to move up.
                        B. At this point, stop and adjust the intake valve on the same cylinder.
                        1) Tighten the rocker until you can roll the pushrod between your thumb and forefinger with the slightest bit of resistance.
                        2) At this point tighten between an additional quarter to half of a turn.
                        C. You have now adjusted the #1 intake valve. You will now want to turn the engine over while watching the same intake pushrod that you just set, it will go full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. By following this procedure, you are assured that both of the lifters are at the base circle of the cam and that there is no additional pre-load applied to them from cam lift at this point.
                        D. You are now able to repeat this procedure on the remaining cylinders.
                        4.Re-install your valve covers and your valve adjustment procedure is finished
                        R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
