Easy enough to find the engine model on the right of the engine, H22A1, but where can I find the actual model of the transmission? Or being the 92 LX with an H22A1 is there only one option?
Tranny Model?
any F22Ax or H22Ax and I think event he F22Bx tranys will fit, it all depends on what gearing you want Close or tall. For example H2U5 is a F series tranny and it is off of a EX trim accord. There is a thread here I will see if i can find it for you to help give you some clarity.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
Originally posted by prophetnite View PostHow do these trannys hold up? Mines shifting kinda rough. It works never have a problem, except its.. well harsh changing gears. A good oil change worth it or just replace it? I dont want to replace unless I have to. Got other stuff id prefer to spend my limited funding on.
let us know what trans you got and that may help with common symptoms.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
Ok, good think Tippey said that! I'd hope you wouldn't put MTF in your transmission... but who knows... I don't want to be the one giving bad advice!
Change the fluid with genuine Honda ATF. DO NOT flush it, and DO NOT use any other fluid.
The automatic transmissions in these cars have often been neglected... the fluid is rarely changed as it should be. By now, most of them are wearing out because of that. The fluid should be changed every 30,000 miles at most!
