This happens every time I start my car up it does the erratic idle between 400-2100 RPMs and then after it's warm it idles at around 700-900 RPMS. I have looked and looked and I have never found a solution to this issue, I suspect it is due to it running lean and needing to change the spark plugs (I just recently changed my intake manifold gasket, causing idle at 3000k+). I have been told the ECU needs to be reset but I don't think that is the case here. Any Ideas? Thanks in advance!
Erratic Idle after start-up and then normal after engine is warm
The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)Tags: None
bumpThe CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
