is this possible and if so will it ruin anything?
Turbo on an auto?
why not?
just need to make sure your tranny is cool.
and don't push too much boost.
other then that it's fine to run turbo on auto.
Yes my name is Dang, Don't use in vain
1992 Honda Accord EX (Coupe/Bordeaux/Auto)
1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
2008 Honda Accord EXL (Coupe/SanMarino/6spd)
Tuning an auto is difficult. Most amateur tuners that I know won't do it. Find a shop that would do your ECU tuning before you even consider it.
Also, turbo on an H22A might not be a great idea either. The compression is high, the motor is old, and it would take VERY careful tuning to make it right.
If you want turbo auto H22 advice, PM blazen_accord. Not sure how often he comes around these days, but he has a turbo stock block auto H22 pushing about 400hp. He's learned his lessons the hard way, though... he has blown a LOT of stuff up in the past!
Originally posted by Raf99 View Postthis reminds me of the V6 accords with auto trannys. the trannys keep failing.
The bad thing about CB autos is that most of them were not properly maintained. The transmission fluid should be changed every 30,000 miles max, with authentic Honda fluid. How many of you have had your automatic CBs for more than 30,000 miles and haven't changed the fluid? If you changed it, how many of you used Honda fluid?
I'd be willing to bet that MOST of you, if not all of you reading this, haven't changed it. Even if you did, the chances that the person that owned the car before you didn't bother.
That's why CB autos are "weak".
Originally posted by deevergote View PostThat was a flaw in those transmissions, though.
Originally posted by deevergote View PostHow many of you have had your automatic CBs for more than 30,000 miles and haven't changed the fluid? I
I put almost 100k on my old auto '92 and never once changed it. It started shifting a little hard, but still drove fine before it was totaled.Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
