Injector troubles.
    Injector troubles.
    Hey guys, im having a few problems with my motor right now. The ecu is throwing a 16, which is injectors. I replaced them with ones that were known to be working, but its still throwing the code and not turning over...
    Any ideas or helpful advice would be great... even my father the mechanic cant figure it out lol
    Bought From : SE_DynamiK, oneoffaccord, and TopCop182
    Click It!>>>><<<<Click It!
    Maybe your injector resistor box is shot?
      That's what I was going to suggest. Try pulling a plug off the injector and see if you are getting any signal.
        Would that be the black box attached to the intake mani?
          No, that is a part of the vacuum system. You'll want the box that is connected to the injectors . It's a grey rectangular box over on the drivers side of the engine bay. It is finned for heat dissipation like a computer heat sink. Scroll about 1/3 of the way down this page to see a picture of a resistor box: http://www.honda-tech.com/showthread.php?p=40341157
            Thanks i will have to check that out now.
              Okay... went out to check the resistor box, and it was unplugged so i plugged it in, reset the ecu ( for shits and giggles) and it still wont start. Although its not throwing the code anymore.
              Edit. I just went to check if the injectors were firing at all. The motor caught fire, but then i put it out after much panic
                WOW that's a crazy story,how was the injector resistor unplugged and how did you catch on fire?
                I know....I'm gunna lower it
                  A stethoscope can be used to listen to the opening and closing of the injector as the engine operates. Good luck.
                  Bisimoto Engineering
                  1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
                  2) Email me, robert@bisimoto.com
                  3) Contact me on AIM, robert@bisimoto.com
                    Okay, ive fixed all known problems with the engine. Vac lines hooked up right, injectors working, fuel pressure is good, timing is good, tried 2 different computers, and the fucking thing still wont start The motor turns over perfectly, but there is just no life. Maybe every 3 or 4 cranks there will be a cough or hiccup of life... but still nothing. I am at a complete loss, and im sick of driving my moms van (even though its an odyssey). Please help me!
                      Have you done a compression test to make sure you have compression in all cylinders?
                      Have you replaced your distributor cap and rotor? Igniter? Ignition coil? Are your plugs fouled?
                      There's still a LOT to check!
                        Compression check is next on my list, tried 2 disrtibutors, both known to be working, plugs are alright.
                          Main relay?
                            Main relay?
                            Perfectly fine...
                              I know it's a stupid thing to ask at this point... but are your battery cables clean and tight? I've had my car crank strong but not start due to corrosion on the cables and terminals.
