Squeaky belt?
    Squeaky belt?
    sup accord bros...i got a problem...when its cold outside, and i turn on the car it makes a squeaky noise like its coming from one of the belts or the gear that turns the belt not sure, but i can tell its this becuz when i rev it it gets faster....im not too sure of what it is...and ive sprayd belt dressing, and wd-40...just makes it quieter but doesnt take it off completly...what can i do it get rid of it 100%?
    You sprayed wd40 on your belts?
    Adjust the tightness. Too tight or too loose will squeal.
    Acutally, now that you've hosed down your rubber with petroleum... replace your belts.
      ok i will..but can u tell me where i can adjust the tightness on it?
        Have you ever replaced belts on any vehicle before? I ask because you have to loosen the tensioner when doing so and that's how you adjust how tight or loose the belt is.
          no i havent....thats why im asking???
            Look right under your alternator. There is an adjuster on the bracket.
            Past 1990 Accord EX Sedan
            Past 1990 Accord LX Sedan
            Past 1991 Accord LX Sedan
            Past 1993 Accord LX Wagon
            Current 1991 Accord EX Wagon
              A haynes manual will be your best friend. There will be a bolt to increase or decrease the tension on the belt, and a different one that you'll tighten to lock it in place once you have the tension where you want it.
                Deev is right, I got some PS fluid on my PS belt, and that wasnt cool.
                But you will need a 12mm socket to adjust the belt.
                  thanks man for the info
                    i cant seem to find it....does anyone have a pic of where it is to adjust the belt???
                      Find the bolts on the parts you need to adjust that don't hold that part to the engine. It really isn't hard. Quite obvious, actually. If you can't find the adjustment bolts, then maybe it'd be a good idea to take it to a mechanic.
                        It's too dark and i'm too full of food right now to move around alot lol. I'll go out in the morning and get some pictures for you though that way you can get a better idea of what to look for. That is if you haven't figured it out already.
                          http://www.cb7tuner.com/vbb/showthread.php?t=140314
                          download the manual for your car and you got your questions answered...
                            I was busy all day and never got a chance to get any pictures for you. Sorry about that. Do you still need help with this or do you have it figured out??
                              yea man i do...dont have the time to be checking for it..can u get me that pic..i just painted my cb7! roll painted....lol like Rexlod.....good guy...
