i just wanted 2 know what kind of tires should i go wet my 94 ex wheels
tires????
If you want stock it's 195/60/15. Personally I'd with this , otherwise you'll throw the speed reading off.
There's come Fusion HRi for $48 each at tirerack. They're pretty nice for all around.
$200 budget will give you crappy tires unless you'd save some more and go for $300 budget.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Originally posted by Konigstiger View PostIf you want stock it's 195/60/15. Personally I'd with this , otherwise you'll throw the speed reading off.
$50 tires are going to be bottom of the barrel tires... They might not even be safe.
You could go with the cheap crap, like Nexen, Wanli, Ling Long... but they're garbage.
Dunlop has always been a favorite of mine (even the lower-end tires from them have treated me well). Kumho has never pleased me. Neither has Toyo. I have friends that have run Bridgestone and liked the performance. Kelly tires are relatively unknown, but a good friend of mine was absolutely thrilled with their performance (I forget the model). That same friend is currently running some high-end Continentals, and he says he'll never buy anything else ever again. Continentals are good stuff.
Originally posted by deevergote View Post$50 tires are going to be bottom of the barrel tires... They might not even be safe.
What do you mean? They have a whole line of Dunlop SP Sport tires. My Fit came stock with Dunlop SP31, which I've already worn out (they wore well, but I popped one, meaning I couldn't properly rotate them...), and I switched them over to an old used set of SP Sport 8090 (which are insane summer tires)
Originally posted by deevergote View PostWhat do you mean? They have a whole line of Dunlop SP Sport tires. My Fit came stock with Dunlop SP31, which I've already worn out (they wore well, but I popped one, meaning I couldn't properly rotate them...), and I switched them over to an old used set of SP Sport 8090 (which are insane summer tires)
