1991 Accord 5spd stuck in 5th
    As the title says, I have a 1991 Honda Accord 5spd that is stuck in 5th gear. Please help.
    it would help if you explain more in detail as to what happened when it seemed to get stuck in 5th gear and what you have tryed yourself to figure out the problem before we can try to do our best to help you out.
      sorry about that.. I was just driving the car on the freeway and it got stuck, was able to get it home. I havent done much of anything, not sure where to start just yet. Thanks
        Even when you turned the car off, it is still stuck?
          yes
            Ah. I thought it might have been like my car when the clutch went bad. It would get stuck in gear and the only way I could get it out was to turn the car off.
            How's the tranny fluid level?
              Sounds like it. Either the clutch or the tranny. But you should be able to pull it out of 5th with the engine not running. So sounds more like a tranny problem.
              My swap thread
              Main relay proplems?--DIY
                hopefully your tranny isn't locked up, or you'll need a new one, this happen alot to my companies truck, locked up in every gear, but once we turned it off it loosens up, they got it to the mechanic and once he opened tranny all the inside just poped out; destroyed
                view my ride: My Ride
                  check your shifter cables.
