Speed Sensor Removal???
    Has anyone know easy way to remove the speed sensor from CB7 with automatic trany?
    I have to change mine but i am not sure if it is easier to reach from the top or bottom of the engine?
    Thanks!
    you have to do it from the top, there's no way to do it from the bottom..
    you will also need 2 long extensions and a 12 socket.....
    1- Unplug the connector.
    2- remove the 2 12 MM bolts
    3- there's another bolt on the bottom.
    4- twist the VSS and pull it up.
    ninja edit:
    read this it may be of big help:
    http://techauto.awardspace.com/vss.html
    JDM Parts for sale
      remove the air cleaner and go from top its easyer.
      my new turbo build
        ninja edit:
        so as soon as i remove the air tube i should be able to see it???
          Lol I have the DIY in my favorites since my speed sensor isn't working, I got one at a junkyard but it was also busted. I actually found the replacing process to be very easy. Well here's the link, I hope you find it useful:
          http://www.cb7tuner.com/vbb/showthread.php?t=115100
          edit: you will need a size 10 socket for the vss bolts.
            That is great, thanks for all the info! I am doing it tomorrow.
            My buddy will let me use his since his car died and his sensor is only 2,000 miles old he got it brand new form the store!!!
              Cool, just keep in mind that they might be different, Im not really sure but I think 90-91 vss have a wire coming out of them(like mine) and 92-93 have a socket on it and no wire coming out of it.
                yea I am aware of that, however he has a 90 lx auto and i have a 91 lx auto it can't get eny sweeter than that
