g22/g23 help needed asap
    really need some help.lol just finish building my g22( h22 head and f22 bottom en) it cranks and spits out fire but wouldnt start. need help asap. cause am bout to burn that car iif it dont start today.
    What do you mean spits out fire? Like actual flames from the muffler?
    Originally posted by 92dm
    I was actually just being a smart ass, and not really contributing to this at all.
    VOUCHES
    Bought from: cb95spd
      spitting fire huh...sounds like ur timing is off. did u do check for spark,fuel.
      my new turbo build
        Timing is off, There is obviously combustion taking place (spark & fuel) if he is spitting fire out the intake or exhaust.
        Did you make sure to use the proper belt and tensioner setup for the G22? IIRC there may be a difference in heights between the F22 & H22 heads. You may be required to use a different belt and or advance/retard your cam gears according to the difference in heights.
        I've never done the build. I'm just going from what I remember reading a few years back. You may want to look into timing setup for the G22 again just to make sure your using the proper timing belt parts.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          the head is actually taller. and the fire is coming from the muffler.lol
