Seafoam?
    Seafoam?
    I just seafoamed my CB,poured it into pcv hose,let it sit over nite.started it the next day it smoked so bad people told me I was on fire.But I took the spark plugs out to look at the top of the pistons and all the carbon was gone! Does this stuff work or am I just seeing things?
    I know....I'm gunna lower it
    WTH!? You left it over night? Isn't it supposed to be left only for like 20 minutes?
    Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
    Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
      You poured it into the PCV hose and let it sit?
      WTF...
      You're supposed to let it get sucked into a vac line, run the engine until it stops smoking, then change the oil immediately. Letting it sit overnight could've caused damage.
      Of course, I put it in my oil (another thing you can do) and drove it like 4500 miles. My engine showed no signs of damage whatsoever, and that's a REALLY bad thing to do! (My h22 has put up with more of my stupid shit and kept going... I'm amazed)
        I might try seafoam.. Will it clean my EGR for me? lol
        -Will
          No, it won't do that.
            I did it almost 3 weeks ago and my engine runs like a champ,better then when I bought the car.No probs what so ever.Anybody have problems with seafoam?
              It's highly corrosive... it can do some serious damage to seals and such... which can cause serious oil leaks. I was lucky. You may be as well.
                I guess I was I'm not burning/leaking oil.
                  Keep an eye on things just to be safe, though.
                    seafoam is fantastic. but your only supposed to put it in your fuel tank, crankcase, and suck it thru the vacuum line. and then you need to drive till its out of the gas tank and then change the oil. otherwise, like Deev said before, it can damage your car.
                    edit: actually i think it says it on the bottle
                      Yea, and since I'am using "royal purple" after I use seafoam (today) I still have to waste $50 on oil which sucks, put seafoam is pretty much worth it (I hear). But good luck.
