I have a 92 coup that seriously needs some lowering. Coilovers are too expensive so I've opted to buy lowering springs and struts. H&R makes a nice set of springs for $265. They will lower my car 1.75 inches in the front and 1.5 inches in the back. I need some struts but I don't have enough money to spend $400 on Koni struts. Does anybody know of a good brand or shock/strut that would work well with the H&R springs. I am also looking into a pair of one piece projector headlights that come with a 8000K HID kit from 4 Car Options. If anyone knows if these suck or not I would appreciate the feedback. They come to about $380 with shipping and have a one year guarantee. They look nice in the picture. I am going to get the chrome/clear ones and the low beam light has a cool looking blue lens and they look like they will be easy to install.
lowering my 92 CB7
If you want good headlights, get projectors from a TSX or S2000 and retrofit them into your CB's headlight housings. Then pick up a decent HID kit and harness to the battery, and you're in business.The results are worth the time and money.
As for the struts... If you have to go cheap, get KYB GR2s. However, it would be much smarter to save your milk money for a month or two and get the Koni Yellows. It's wintertime... you won't be able to enjoy the suspension fully this time of year anyway. Save your money, and come spring, get the good stuff. Seriously. H&R springs on Koni Yellows are an amazing combination.
Originally posted by deevergote View PostIf you want good headlights, get projectors from a TSX or S2000 and retrofit them into your CB's headlight housings. Then pick up a decent HID kit and harness to the battery, and you're in business.The results are worth the time and money.
Koni yellows are good for anything.
However, most coilover sleeves are garbage. If you want sleeves, get Ground Control.
Personally, I feel that a set of well-engineered springs are the best for an amateur tuner. The make proper use of anything adjustable, you need to know what you're doing, and be in a situation where you can properly test it... like on a track.
The Konis are adjustable... but I leave mine on full soft when driving on the street. On the drag strip, I turn them to full hard, which is scary on the street. That helps reduce squat. Other than that, I don't mess with them.
It makes no difference. I would stay at full soft for comfort and reliable handling. When you stiffen it up, you run the risk of losing control.
I drive for a living, and one day I lost my adjustment knob (after going to the track the night before). I was able to adjust the fronts using a couple keys... but the rears were too difficult to do it that way due to the angle. I worked with just the rears on full stiff, and it was terrifying.
Originally posted by deevergote View PostIt makes no difference. I would stay at full soft for comfort and reliable handling. When you stiffen it up, you run the risk of losing control.
Damn. That's a recipe for breaking the rear end loose at any moment.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Originally posted by 92smokeaccord View Postso i should have soft for a dd and stiffin them up when i want to go race.is that what ur sayin?
Originally posted by GenDBlade View Postyes. riding around with stiff suspension is like riding in a red ryder wagon down a hill. you feel every bump
